Keyless go passenger side not working
2013 C350 CGI Sedan 4Matic
Hi there,
I’ve had a problem with my rear passenger side lock and window working intermittently. I finally took the time to trace the issue to the wiring harness. I replaced it recently with the exact same part number.
When I put it all back together, everything worked well, except that the keyless entry on both front and rear passenger doors now doesn’t work. It used to work. Does anything need to be reset? Any ideas?
The locks work when I use the fob, the main lock switch or use the keyless entry on the driver side. It’s as if the sensors on the passenger side don’t work at all.
Thanks!
Thanks!
