2013 Hi there! right had an overboost P0234 on C Class w204
Just getting the same code with mine
. What was the fix for your over boost condition ?Are there any other codes? Have you scanned your car with a Mercedes-specific scanner. (Search the forums for "baby scanner" for a discussion.)
When I cleaned the intake manifold I took off the swirl motor off and believe I didn't zero it dout properly. I pull it back off off and Zero it out to the one o'clock position before installing it again. I used brake clean to clean it and realized after that wasn't a good idea so I purchased 3 new Bosch pressure sensors from rockauto.
Took the car out for a drive and it went into lip mode revealing the above codes.
I figure it has something to do with the new sensors. I did a little digging online and found Mercedes has a different part number for each individual sensor, so I am thing they're not interchangeable. Any thoughts ??
Lastly as the car is old I am going to replace the vacuum lines/actuator/seleniod and that three way pressure switch.
Pat
I figure I would
