Throttle valve acutator errors + limp mode
New on here so bare with me. Hope that I'm not repeating this topic from elsewhere :P
So I'm having trouble with my grandads W204 C180 2012 1.6L 156HP. Car is going into lip mode more and more often. Bought the icarsoft i980 to diagnose.
Getting the following errors:
P210100 - the throttle valve acutator has a malfunction
P210128- the throttle valve acutator has a malfunction. The signal offset is outside the permissible range
P210184- the throttle valve acutator has a malfunction. There is a signal below the permissible limit value
P033904 - Position sensor 1 for thr crankshaft has a sporadic malfunction. There is an internal fault.
I'm a bit lost where I should start with this. Anyone else have this combo of errors?
Many thanks in advance.
Best,
hjandrzej
