What do i need to know before buying a W204?
Old Feb 24, 2020 | 09:16 PM
EdmondB's Avatar
VW Passat
I've driven a VW for a long time and i'm looking to switch over to Mercedes and i am looking at both pre and after facelift models, years from 2008 to 2012/13. I wanted to know if the W204 is reliable, does it have automatic gearbox problems (i've had a lot of troubles with DSG gearboxes that cost me thousands of dollars). Are the gearboxes dual clutch or torque converter? Is there any model that i should avoid?
Where i live, most of the cars are sold at around 150k - 200k km. Are these cars reliable after that much usage?
Lots of questions i know, but i've been burned by the DSG before so i'm doing a thorough research before buying a new car.
Old Feb 25, 2020 | 03:55 AM
xsever's Avatar
2012 C300 4MATIC Sport
Here's the logic I used when buying my car:
For the sake of looks and technology, you should definitely go with facelift which means 2012 or 2013 or 2014.
The 250 M271 EVO 4-cylinder engine is not reliable at all with timing chain stretching, turbo problems,and high-pressure fuel pump (HPFP) problems.
The 2013 and 2014 C300 and C350 use the brand-new-then M276 V6 engine which had the following problems: HPFP, check valves installation requirement to eliminate knocking sound on cold start,
This leaves you with the 2012 C300 4MATIC which uses the super reliable M272 V6 engine and the 7G+ transmission (torque converter) which was also reliable by then.
This is how I ended up with my car and I've been very happy with it with no problems.
Old Feb 25, 2020 | 10:27 AM
TheRulesLawyer's Avatar
C350
Yah, 2012 C300 is probably the best bet from reliability standpoint. Though if you get a rwd model instead of 4 matic the transmission doesn't matter much, it was the transfer case that was the issue on earlier cars. I'd still stay 2010+ since there were a few issues early on. I don't think the m276 are super problematic, but the m272 is pretty bulletproof by EOL. You do give up quite a bit of power if that matters to you.
Old Feb 25, 2020 | 02:04 PM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
2008....
1-Bushes front, wheel alignment.
2-The steering lock issue.
3-Condition of shocks and which type-?
4-The belt and front pulleys and tentioner condition.
5-Last battery replacement.
6-Gearbox service history.
7-Brakes, discs etc.
8-Lived in garage or outside under trees, rust/corrotion.
9-The rear wheels linkages rust issue.
10.On cars like these I would get oil samples, fluid samples and have it analised, thats what I did with my new vcar out of gurantee deciding to keep it.
Old Feb 25, 2020 | 04:32 PM
DrivingForce's Avatar
2011 C300 Sport, 6M, Dynamic Handling Pack
I'm partial to the pre-FL models. IMO I like the 2011 best. The headlights on the FL models look cheesy to me. I believe 2011 is when they started with the LED DRLs but it still has the pre-FL headlights. The interior of the post-FL models is radically different with the dash design. I think the pre-FL interior is more attractive, but definitely doesn't appear to be high tech if you care about that sort of thing. I like how simple it is with the center console closed, and the dash feels really low.
Then again, age and mileage would probably steer you towards a newer model.
None of these are my car.
Old Feb 26, 2020 | 03:36 AM
xsever's Avatar
Only the OEM halogen ones yes.
The bi-xenon models, whether OEM or aftermarket, look much much better than any other headlights on pre-facelift or facelift W204.
Old Feb 28, 2020 | 10:07 AM
ezshift5's Avatar
Mercedes C250 Coupe
A C250 + a VW live in my garage. Both have been sin problemas since purchase. One of the major factors in the MB purchase involved noting the 16 or so green reliability circles for the 2012 MY by CU. IMHO - they were correct. Since 2014 purchase I've not had one problem surface on my (good looking) Iridium coupe.
all the best,
ez
Old Feb 28, 2020 | 02:00 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Not sure where you live, but 150-200k would me my concern.
Can you purchase from somewhere else and buy one which has done around 100k km that way you could own it and drive another 80k? and still be good vs 200k and adding another 80k in to it would be more likely to encounter some sort of $ problem.
If you are after the 4 cylinder model like I have at 200k the cam chain would be stretched, sprockets worn and should have had 3 transmission services, good chance is none of these items were taken care of properly.
Old Feb 28, 2020 | 03:34 PM
My 105k mile W204 (170km?) drives pretty close to how a new one does. These cars seem to be very well built
Old Feb 28, 2020 | 04:24 PM
catmandoob's Avatar
'08 C300 4Matic Sport / '11 C63
It does depend on ones interior preference, I kept pre FL on both of my W204 because I actually love the pop up screen. I know all are going that way but I don't need an ipad everywhere I look.
Anyway, others have mentioned it, by 2008/2009 M272 is pretty bulletproof all around. If you can find one with service records it should be pretty good to go.
All have the ESL issue but that is remedied by a $5.00 Chinese motor as a preventative maintenance step if one is smart.
I will say double check brake lines as a couple of us have had corrosion/rust issues especially under rear end and trunk area where the line crosses for passenger rear caliper for mine, although cheap fix if you do it yourself it's pretty sketchy when you can't stop anymore.
Some have had bearing issue in trans and or transfer case for 4-matics but it doesn't seem to be very often that you see it, so not a major worry in my book (as long as decent service records are linked).
Got a 105k miles on mine and plan to keep it forever as I have my w202. Reliable car in my book. Wouldn't hesitate to buy another one in a heartbeat.
If you can the C300 for 2012 with the M272 is best deal because it is actually the 3.5L M272 so you can tune it right back to where it should be and have plenty of power.
