Parking light sockets.
Old Feb 26, 2020 | 07:49 PM
Dark300's Avatar
2009 C300 Sport
So like it seems to be common. My parking light sockets are melted, I swapped to LEDs about a year ago but now one won’t work at all. Swapped it with a known good one and nothing. I searched but everything I came up with was old. My question is has anyone found a replacement socket for the bulb like I said all the posts I found had links that were not good anymore and I’m tired of seeing a “check parking light warning”
Old Feb 28, 2020 | 07:47 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
https://www.rockauto.com/en/catalog/...al+socket,4092
This part appears all over but RockAuto is the cheapest. You have to fish out the wires from your headlight/parking light (those "can MB use a cheaper, thinner wire!!") , get 2 lengths of new wire, long enough to give you some better work room in this snug spot. I cut the OEM wires at the base of the melted socket, carefully stripped the insulation(fragile here), twist joined the new wire(s) which I had added to the other end(s) the socket you have to assemble (the metal prongs the bulb slips into with wires crimped, grommets, it will be obvious). Tried to heat/solder the twisted new wire/OEM wire but looked like insulation was going to melt away into the depths of the headlight case so twisted tight and coated with Superglue, followed by a smear of RTV to further insulate. Has lasted a year plus so far. A PITA because of the location with little room to attach and insert new socket but doable.
