Need help with missing sensors on C300 4MATIC
2010 c300 4matic
Hello! I am a first time poster, but many time viewer. I am a huge fan of this forum indeed!
Here's is my problem:
I had a front impeller shaft drive failure last week while on the interstate. As part of that catastrophe, I lost the lower O2 on the CAT, a large bracket of some sort that was attached to the side of the bell housing, which was made of heavy gage steel I might add, and then it appears, two sensor connections (male to female)that clip into a bottom bracket that is attached to the bottom of the bell housing. GONE, just gone.
These are the two that attach on the right side of that bracket. The other two on the left side are still intact. Can anyone tell me what these are so I can buy and install new ones? I called mercedes with the part number for that bracket so he could locate the diagram and help me out, but he was worthless as he needed to know what the part numbers were for those electrical parts and what system they belonged to. he told me to bring in the pieces so they could identify them, geez I guess he didn't quite understand that I lost them somewhere on the interstate!
2010 w204 C300 4MATIC Engine: 272.94 Trans: 722.9
Please help if you can,
Thanks - Dave
Thanks - Dave
