M271 Evo Engine Noise Problem
It may be best to take it to a garage and let them listen to it, just hard to hear with your video clips to me sounds like crankshaft bearings rumbling when the engine is accelerated which would also be related to low oil pressure.
greets Ricardo.
im sorry for my bad English.
I also own a slk200 y13 with an m271 engine.
It is the same symptom. When the temperature is high, the noise is heard at about 50 km/h at 1000~2000 rpm, and it is louder when decelerating.
Refer to the comment on the 2nd video on the top post
I replaced it with SHELL 10W60 oil and the noise was slightly reduced.
The previous oil was Mercedes-Benz oil, and I tried the 5W30 and AVENO 5W30, but it was the same.
I know it costs a lot to work with plugs.
I don't want to pay any more. It's because you've already done meaningless cam adjust work.
Did it happen again after driving for how many kilometers after working on the tensioner plug?
Or if the problem is caused by low pressure due to oil leakage
I wondered if adding a little more oil than recommended would solve the problem. Of course it would be dangerous
Anyway, I'm curious what action you've taken now.
I had the same noise as above between 1200-1500rpm when slowing down. The noise was scaring the crap out of me, it was suprisingly loud when it happened (not all the time). The plug of the tensioner (oil pump chain) had fallen off like seen above, and after replacing the part with new one that had an aluminium plate on it, the noise disappeared and is yet to come back since (driven now about 1000km). The aluminium plate was selfmade, dealer did not have any solutions for this. Yet they said that the car should not be driven without the plug.
I'd like to ask does anyone else have a loud chainlike noise between about 2000-3500rpm (especially when accelerating)? No noises on startup or anything else. The sound was there before fixing the plug problem and is still there eventhough everything from timing chain to sprockets were also replaced. I just dont know if the SLK should sound like that or not. Could it be because of the SLK's sound generator thing that boosts enginenoise (mine probably has it since it has the amg package)?
"quoted"
Is it necessary to remove or loosen the transmission mount when you lifted the engine?
I hear the noise when I'm slowing down, it drives me crazy.
I think I spent 3000 dollars, too.
If I find a way, I'll share it with you.
Currently, I don't want to add more oil because of the plug plug, but I can't do anything because of the oil leakage.
I have same problem too.
My car is W212 E250 cgi (e/g is M271 evo.)
Its camshaft adjuster and chain were changed new a year ago due to recall by Mercedes Benz Japan.
But its problem of rattle noise appearered last month.
Mr/Ms. chipset told us about this issue due to the plug of the tensioner attached to the lanchester and crank gear.
But I think that changing the tensioner to new is taked a lot of money and time. (Moreover, recurrence even after repair may be.)
So, I want to explore other way. (But I have no idea.)
If you know other way or have a new idea, please tell me.
Thank you.
(I'm sorry about my poor English.)
m271 evo
w204
1.8L 4Cyl
156hp
250nm
2. So the culprit is definitely the oil pump chain tensioner plug that's causing the low oil pressure that leads to this noise?
3. Just replacing the chain tensioner should fix the problem?
m271 evo
w204
1.8L 4Cyl
156hp
250nm[/QUOTE
Hey. Can you share how vacuum brake pump solve the noise? How do you notice the vacum brake pump is the culprit?
m271 evo
w204
1.8L 4Cyl
156hp
250nm[/QUOTE
m271 evo
w204
1.8L 4Cyl
156hp
250nm
My car, Mercedes C250 Sport W204 (M271 DE18LA EVO 271.860) , had the same symptoms as described previous comments, eg.: noise between 1200-1500rpm when slowing down.
Complete timing system was replaced, adjusters, central valves, valve solenoids, all sliding rails, all tensioners, tensioner bracket, chains, pins, position sensors! Firstly only the mechanical parts were replaced and later the electrical parts (solenoids, sensors). After each step the engine was better and better, but still not flawless. Everyone thought and everytime the oil pressure is the issue. Never was!!!
The break vacuum pump (A271 230 1665) is attached to the exhaust camshaft. Only 2 screws hold it, so I managed to replace it, here is a useful guide for the process (which is a little bit tricky because of the small room to loosen and tighten the 2 screws):
My assumption is the pump created unnecessary and not constant load to the timing system via exhaust camshaft. The difference of the rotational resistance between the old and the new pumps was clearly felt by hand.
Good luck!
