A fuel system fault
W204 C220 CDI
A fuel system fault
Afternoon! First post here....
I've got a late 2007 W204 C220 CDI, 90k miles. I've got a fun fault with the fuel system. Symptoms are:
Any help would be much appreciated, or at least some advice on which part might be worth replacing, or anyone who has had the same symptoms and then luck on repairing this themselves?
Cheers all!
Dan
- When giving it the boot from stationary, I get a 'blip' in power for about half a second
- Occasionally I get the ESP light at that point, and when that happens, I have the EM light on (which goes off after the car has been stopped and started a few times)
- I have both P0088 and P0087 fuel pressure faults
- When cold and ticking over, the engine misses a beat occasionally
- The car has 18" wheels (I was originally told the ESP issue was a tyre pressure sensor fault related to this but I don't think that was right?)
- I also have throttle pedal sense code P0123 (which I thought was the cause the power blips)
- I also have shaft sensor fault P0340 (which I also thought was related to the power blips)
- The fuel quantity control valve
- The fuel quality control valve (are they the same/similar thing? There seems to be confusion over that)
- The diesel temperature sensor
- High pressure fuel pump and associated sensors
- The fuel rail (please god no!)
Cheers all!
Dan
Cheers all!
Dan
Cheers all!
Dan
my car performance acceptable, I did check the fuel pump , fuel pump screen, fuel hoses and change fuel filter
I think that because of bad fuel quality
Cheers all!
Dan
Cheers all!
Dan
i noticed your post is now 2 years old. how did you go with the problems. I have a C220 CDI 2009 190Klm and having fuel issue problems. have changed the tank pump and the Fuel rail pressure sensor. still having problems
Please have you found any solution yet?. I have similar problem
