hud install
First problem is the inaccuracies. Straight away every metric it displays is wrong. They can be adjusted but I can’t be bothered to go through calibrating every unit.
Next, the unit i chose is too big. It doesn’t sit flat on the dash of my C63. I did find a place to put it but the base is too big.
If I was to get another one I’d get a smaller unit that only displays your speed.
Also, don’t use the rubber non-slip mat that comes with it. This will melt in the sun. Affix the unit to the top of your dash with some double sided sticky tape.
Got mine on aliexpress.com but you can find them on amazon also but more expensive.
https://m.it.aliexpress.com/item/400...40166744TZQtPA
