NASTY sound from transmission (video)
Old Aug 10, 2020 | 02:35 PM
BenzBoyo's Avatar
2011/2012 C180 Coupe (petrol)
Exclamation NASTY sound from transmission (video)
Okay I just recently bought a 2011 (2012 model year) W204 coupe (C180 1.8) with 75k miles on it. For the first 4 years it was serviced at the dealership and after that some local car shop
Whenever I do a COLD start > put gear selector from P to R > proceed to reverse for a few meters > put gear selector to D, THEN, just as I put the gear selector to D for trying to go forward, a nasty creaking/screeching sound appears for a moment.
I created a short audio video - turn your volume up a bit and listen at 1:13 - 1.14 in the video - THAT is the moment when I put the gear selector to D as described above - you hear a nasty sound.
What is it and what should I do about it, it only happens after a cold start. Did I get scammed out of my money or what...But other than that the transmission seems to work fine...
Please follow the Youtube link:
Old Aug 10, 2020 | 03:05 PM
alecmascot's Avatar
W204 C220CDI 2011
I think it is the rear brakes.
Old Aug 11, 2020 | 05:15 PM
atikovi's Avatar
1995 S280 5-speed
Maybe the fan is touching the shroud as you shift due to a soft engine mount. First figure out where the sound is coming from. If the transmission drives fine, I wouldn't worry about it.
