722.9 Valve Body Torque Specifications
Old Nov 5, 2020 | 05:32 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
Does anyone have the torque specifications for the 722.9 valve body to trans housing and conductor plate bolts? From my research, the pan bolts are 4NM and 180 degree.
Old Nov 5, 2020 | 05:49 PM
Bolt, Solenoid valve to shift plate = 8Nm
Bolt, electrohydraulic controller unit to transmission housing = Stage 1 Nm 4, stage 2 90deg
Solenoid brackets (leaf springs) to transmission housing =5Nm
Just found these, would like confirmation if that is the correct specs. Thanks
Old Nov 5, 2020 | 09:16 PM
chassis's Avatar
2017 GLE350 4MATIC
Correct on leaf spring and conductor plate to housing screws.
Conductor plate to housing screws are single use and are specified to be replaced.
File Type: pdf
Old Nov 5, 2020 | 11:56 PM
Excellent, thanks for that!
