Extended Warranty on Camshaft Adjusters
Just became a forum member, as I too have the camshaft issue. My 2012 C250 with 69,000 miles triggered a CEL about 2 weeks ago and has been sitting at a dealership for a week now, as Mercedes has denied the claim based on the date the car was initially sold. Since the car was initially sold in October 2011, the car is now past the 10 year extended warranty by 5 weeks. The dealership says they tried hard with Mercedes, but they are taking a hard-line approach to the date. I contacted Mercedes directly and they are "reviewing" my case. I argued that my car is a low mileage vehicle and since the pandemic hit in spring 2020, it has been driven even less. With the CEL being triggered at around 75K and Mercedes announcing the extended warranty in November 2020, it would have been hard for me to get my CEL triggered.
To add more salt to the wounds, I never received notice from Mercedes that a potential problem existed and that an extended warranty was available. I started exhibiting problems with the car for several months now, but I never put 2 and 2 together. For example, the car was smoking a bit more and there was black soot around my bumper. I thought it was the turbo banjo bolt issue and contacted the dealership to ask them about the banjo bolt. The service advisor said my car was not affected by the banjo bolt and didn't advise me of this extended warranty on the camshaft. If I had known this was the issue, the car would have been driven a hell of a lot more to try to get the CEL to turn on.
Hopefully Mercedes will make this right, but I am not counting on it., Dealership says it will cost $2900 to repair, which includes a new timing chain as mine has stretched.
They could care less, they just denied fixing my high pressure fuel pump because my car is past the 120,000 mile mark. They also denied it five years ago because I was a month past my four year factory warranty. Yet they are allowed to wait ten years to extend the warranty to ten years where it’s already expired.
can’t wait to ask them to reimburse my 3,000 for camshaft repairs so they can look down upon me for being the second owner of the car and using an indie shop lol. Use Mercedes to fix the car they built that has had several engine failures before 70,000 miles? I absolutely hate these people with a passion. My beater car in college was more reliable.
Just joined to outline my experience with Mercedes and the camshaft Issue on my 2012 c250.
In short, after noticing a rattle during startup I found this thread and suspected my car had this camshaft Issue. The bad part was I didn't have a CEL but decided to take it into the dealership anyways since my extended warranty expires in a couple months. I told them my suspicions and fortunately they came to the same conclusion after the inspection. I didn't mention anything about a CEL and it's probably a good thing not to unless they ask since the extended warranty seems to require that to be on the car during inspection. Anyways my car was in and out in a few days.
This thread had me concerned that I wouldn't be able to get the warranty since I didn't have a CEL at the time I brought my car in. But my experience went against that, so give it a try if you're in the same shoes and maybe try with different dealerships
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
In November 2020, Mercedes Benz began sending letters to owners of 2012-2014 C250 Sedans, 2012-2015 C250 Coupes, and 2012-2015 SLK250's notice of extended warranty coverage for the camshaft adjusters for a total of 10 years or 120,000 miles.
This coverage applies to all cars of these classes with the M271 engine regardless of ownership. If you have not yet had the work done, the coverage only applies to work done at a dealership. If you have already paid for the work done at a dealership, you should be reimbursed by showing a receipt. Work done at independent repair facilities may or may not be covered.
You must talk to a service manager. Service advisors or other persons may not have the information to properly handle your claim.
If you have not received this notice, contact the nearest Mercedes Benz dealer.
Mercedes Benz Customer Satisfaction is at 1-800-367-6372. They can direct you to a dealer and will put your name in a queue to be contacted by a service manager.
Good luck!
Good luck!
There is plenty of discussion on the W204 forum about the camshaft adjusters on the M271 EVO engine. The symptoms are harder starting, check engine light, possible "rattling sound" for a few seconds after engine fires. If you have the CEL diagnosed, OBD will show DTC P0340 "Timing Sensor Bank 1."
They seem to begin failing at around 75,000 miles. This is very early as all our other MB cars went well past 150,000 miles with no major engine issues when we replaced them.
The timing chain is also a potential weak point around 100,000 miles but not covered by the extended warranty. Since the cover was already off, I had the timing chain, guides, and tensioner all replaced at the same time.
2. Short Test Documentation with fault code information (P001477, P001600, P001762, P001662, P001177, P001700, P001192, P001492, P034062, P036662) must be attached to all returned camshaft adjusters.
P001667 is not included in the list.
If it’s beginning to fail, drive the car. Other codes should begin to appear shortly.
Hello!
I believe I'm experienceingthe same issues with my w204 2013 c250 coupe however, I haven't received any letters regarding the extended warranty of the camshaft adjusters. how should I proceed?
The coverage extends for 10 years or 120,000 miles from the original purchase date of the car. Scroll down this thread for actual warranty statements from Mercedes Benz.
Note that MB is requiring the existence of specific diagnostic trouble codes (DTC) associated with this failure for coverage. After the car detects the code a few times in a row the check engine light (CEL) will come on. Even if you do not have a check engine light, you can check for the code with a personal scanner or, if you don’t have one, most large auto parts chains will scan your car for codes for free.
Record the codes found. Do not clear the codes.
The most common DTC for the camshaft adjuster failure is P034062. Others are listed in this thread.
If you have one of these codes and your car is within the extended warranty period, take your car to a Mercedes dealer for extended warranty coverage. You may have to talk directly to a service manager because service writers may not have the authority to extend warranty coverage.
If you don’t have one of the listed codes, it may appear after a few weeks of driving. But be aware that a stretched (worn) timing chain, or a failed chain tensioner could result in the chain jumping a link and causing serious internal engine damage that is not covered.
If your car is outside of the extended warranty period, either a dealer or an independent shop specializing in Mercedes can diagnose and solve whatever the problem may be. The independent shops are generally much less expensive.
Thank you for you reply!
I took it to my dealership (in Canada). While they claimed they didnt know about any extended warranty on the camshaft adjusters, they said they'd cover it if I had any of the fault codes showing (I had printed out the warranty update from Mercedes and handed it to them when they claimed they didnt know about this).
I have called Mercedes Benz Canada, and have confirmed with them that my car is eligible and is covered under this extended warranty and that they had sent out letters regarding the camshaft adjusters extended warranty in April 2020 - I have not received any such letter from my dealership and that's not due to them losing my address, I regularly receive letters from them including one for the extended warranty on the high pressure fuel pumps.
Ill keep driving carefully until one of the fault codes show up and hopefully it does so before any damage to other components
I noticed that you mentioned they also covered the replacement of the tensioner and the chain for you (even thou its not covered under the extended warranty). Do you have any suggestions as to how I may be able to get/ask them to cover the replacement of the chains and tensioner as well?
You might drop the hint that you would view them favorably on your next purchase.
Lets hope that the DTC shows up soon so you can get the warranty coverage going. The time between the rattling noise on mine and the first CEL was a few weeks. I drove it for a while after that without issue, but I don’t drive very hard. If the warranty coverage kicks in, the car will already be apart and that will absorb the labor part of the chain and guides along with the adjusters. The chain and guides are definitely the lower cost components.
Can you continue driving without fixing issue?
I got the check engine light a few days back. The dealership said code is p001477 and p001177.
however check engine light is gone after getting car back from dealer.
can i continue driving without damaging timing chain ?
I am unable to do repairs as i am 3 months out of warranty. Dealer is charging $5500 !!!
here is what dealer says
TIMING CHAIN HAS STRETCHED CAUSED BY STICKING CAM ADJUSTERS SO NEEDS CHAIN- TENSIONER-ADJUSTERS $5446.00 -INCLUDES OIL CHANGE AFTER REPAIRS
-NOISE AT 20MPH IS COLLAPSED ENGINE MOUNTS CAUSING A VIBRATION NOISE $1200.00
I could take exception to the way the dealer stated the problem, but it’s serious.
I’m going to assume that you’re not deep enough into DIY to attempt this repair yourself. It’s something I can do, but I don’t want to. It’s time consuming, uses special tools, and is near expert level.
An independent German car specialist shop could probably cut that estimate nearly in half while still using Mercedes parts.
There are much less costly aftermarket camshaft adjusters available. I don’t have any direct experience with them, but I have heard they are not particularly reliable. Then again, the original ones weren’t either. If you want to risk it and the shop will do it, then you could get the repairs down quite a bit more.
Aftermarket timing chain and guides are no problem if they come from a well known manufacturer. A good shop should know.
Keep us posted on how you move forward.
Hi Does replacing the camshaft, replacing timing chain and the tensioner’s require that the engine be taken out of the car ?
if so then I would prefer to get it done at a dealership otherwise I wouldn’t mind doing it at a small shop that can do it for half the price but I want to understand if it is a big fix??
also since the check engine light has gone away can I continue driving the car without fixing this problem ?
Hello, I had my two cam adjusters and the tensioner replaced for free from a Canadian dealership under the 10year extended warranty. They did not however replace the timing chain.
They could replace it with extra cost to me but the head service manager said that its extremely unlikely that the timing chain would be bad/stretched given the fault codes, service maintenance and mileage of the car. Heeding his advice, I did not replace the chain.
Although its been only a month of driving, all the problems seem to have gone away for now.
I did thou explicit ask whether bad adjusters can damage the timing chain and/or the other way around and he said no whatsoever - Is that really true? dsumit's diagnosis seem contrary to what my service manager said.
Did I shoot myself in the foot by not replacing the timing chain at the same time?
As your car is beyond the warranty period, I would recommend using an independent German car or Mercedes specialist shop. It’s a moderately large repair, but not extensive like a rebuild.
If my experience is an indication, the CEL will come back on over time. The CEL is triggered by (I think) 3 consecutive timing errors. It will go off after being cleared. It will also go off after 3 consecutive starts without a timing error, but a permanent DTC will remain in the background.
Thanks for the reply, I guess ill plan to replace the timing chain around then
Can bad adjusters can damage the timing chain and/or the other way around?
And other than the cold start rattle, what are some other symptoms of a worn out chain?
Same exact thing they said to me last week!
they claimed I needed to pay the about the same amount ($5000 or more )because “the camshaft spring was missing” I told them to gladly bring the car back around and no thanks. Although I need the car fixed to pass my smog check, I’m not paying them half the value of the car for a “spring”. Any suggestions on this???? I’m really at a standstill
