ECU issue?
Old Feb 11, 2021 | 02:36 PM
Mujahid Ali's Avatar
W204 C180K
ECU issue?
Hi, my name is Mujahid. I have owned a W204 C180K 2007 for about 2 and a half years. No major issues up until now. My car doesn't start when turning the key and I get the the ESP inoperative sign and cruise control inoperative. I also notice a clicking sound from the SAM module area after the car has been swithced off. I've taken it to the garage and they've said that the ECU is not communicating with the ABS, gearbox and engine management modules. This could be an ECU fault but he said he is liaising either MB tech support for further advice. He said that he noticed some corrosion and possible signs of water ingress. He alsp mentioned replacing the ECU, but I'm worried that after spending a lot on a new ECU, that the issue remains. Any advice?
Old Feb 16, 2021 | 12:52 PM
W204 C180K
Originally Posted by Plutoe
Get a proper DAS Xentry scan---then you will know the truth, otherwise continue on with the FUYAA and get nothing
I took it to a MB specialist. They confirmed it wasn't an ECU issues, they have found water inside the car. They're trying to find out how the water got in there and check which connections have been damaged.
