Normal temp ?
Old Mar 7, 2021 | 02:26 PM
Jankot's Avatar
C200
Exclamation Normal temp ?
Hello,
i am new in this forum and i have a question regarding the normal operating car temp.
my w204 2010 is running from 98c - 208f up to 106c- 222f ...
i got my self an ultra gauge to keep my eye on it and i found that at 106c - 222f the thermostat open and takes the temp to 98c-208f
is this normal or there is something wrong ?
Old Mar 7, 2021 | 02:33 PM
ezshift5's Avatar
Mercedes C250 Coupe
Originally Posted by Jankot
Hello,
The temperature gauge on my C250 coupe - when fully warm - shows the pointer just touching the top of the "80".............
ez
Old Mar 7, 2021 | 02:45 PM
Jankot's Avatar
C200
Yes me too but the ultra gauge OBD2 tells me it is 106c-222f and the pointer is still above 80 ..
i am worried so that the engine won’t die sooner since it is operating hot .
don’t know what is the normal temp so i can look into it if there is something wrong .
Old Mar 9, 2021 | 12:28 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
This is not technical, just my experience. None of my Mercedes Benz cars or SUVs have had a normal operating temperature above 90 C, 194 F. My 2013 C250 sedan runs around 85 C. The 106 C opening for the thermostat seems higher than normal, but may not be damaging to the engine.
Old Mar 17, 2024 | 01:26 AM
Jeff Pinson's Avatar
C250
Hello,
I think it's normal. I just replaced the t stat on my daughters car with one from the MB dealer. The car has always been what everyone else shows on the gauge and still does with new T-stat. When I have the ODBII adapter and Torque app running I get the same, goes up to 106c when opening and goes down to 93c when its not hot outside. I suspect when it warms up outside more fluctuations will be same.
Old Mar 17, 2024 | 08:35 AM
JettaRed's Avatar
Veteran: Army
My normal coolant temp is 198°F. Rarely does it go above that. The oil temp will settle within 10° of that number but is usually at the same temp after driving a while. The oil temp is at operating temperature at 176°F and turns white. This display is from the AMG menu Instrument Cluster mod from @BenzNinja .
