C250 misfire
Old Mar 8, 2021 | 06:04 PM
Nikmarques's Avatar
2012 c 250
C250 misfire
2012 C250 4 cylinder throws cylinder 4 misfire code and runs very rough when 3/4 to full throttle. Code goes away when you turn it off and back on, runs fine. Happens in any gear. I switched coil packs and cylinder code doesn’t change. Any ideas? Could it be some type of Valve sensor? Injector? Seems to be electrical.
Old Mar 8, 2021 | 09:14 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Remove the coil and look for oil leaks around the spark plug hole. Leaking gasket can cause misfires.
