2008 C350 Weird Temp gauge problem
2008 C350 Benz
Hey guys, I just replaced my radiator as of yesterday, the system has been bled and I topped of the coolant with OEM this morning. Later tonight when I pulled into the driveway my temp gauge red at 100-105 usually it sits at 92-94. Then I went up to 120 almost at red. Is it possible that I have a air pocket or should I be worried about a bad water pump?
If you didn't have this issue before messing with the car...... Then is possible that there air in the cooling system. I use a vacuum device to fill up the cooling systems.
