CAN junction block locations? (Water damage?)
Old Aug 3, 2021 | 09:23 AM
tofu-'s Avatar
c63, 335i
I'm having problems with my 2009 w204. No ac, no blinkers, brake light on, high beam light on, check engine on, no horn, srs light on. There has been water ingress in the cabin over the years.
I checked the front Sam -- absolutely no water ingress; circuit board and connectors look flawless.
Swapped 15r relay - issue persisted.
Cleaned the 3 can junction boxes to the left of the driver footwell because there was mild corrosion - issue went away during cleaning then returned days later. I think it was coincidence. I'm getting about 2.5v on each wire except one brown stripe one, which I'm assuming is a ground because it looks different than the others.
Are there any other can junctions in the interior that may be corroded? I'm really stumped here.
Old Aug 3, 2021 | 02:45 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
I would go back to the 3 junction boxes re-clean then and see if any difference can be detected.
have a really good look up inside all the terminals for corrosion when you are finished apply some dielectric grease.
Old Aug 3, 2021 | 03:06 PM
tofu-'s Avatar
c63, 335i
Originally Posted by NZ-Merc
Hi
I'm just going to replace them. Didn't realize they're only $10 each. I'm hoping this is the issue despite looking perfectly clean now
I was considering steering column, but that wouldn't explain the ac not working
I'm hoping it's not the front Sam, because I don't have the means to program that myself
Old Aug 6, 2021 | 01:48 PM
tofu-'s Avatar
c63, 335i
Just a small update,
The distribution boxes fixed it. I took the old boxes apart for inspection, and I really didn't notice any more oxidation on them (they had been cleaned with deoxit), but they were still inoperable. So, if anyone is googling this issue -- although the distribution blocks may look clean and you have 2.5v on every wire, it's worth replacing them.
All fixed.
Old Aug 6, 2021 | 08:55 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Happen to have the part numbers on those distribution blocks...for a 2009 C300, right ?
Old Aug 6, 2021 | 09:00 PM
tofu-'s Avatar
c63, 335i
It is for a c63, so the part numbers may be different. I'd double check
004-546-76-40
004-546-81-40
004-546-82-40
Old Aug 7, 2021 | 07:38 AM
gamma300C's Avatar
Thanks.....Mercedespartswholesale. cross referenced those part numbers to a c300 also.
Old Aug 7, 2021 | 11:15 AM
tofu-'s Avatar
c63, 335i
And to add to the Google keyword list, I also had intermittent issues with starting the car. It would not crank unless I tried 3-4 times. Lastly, I also had an intense vibration during idle while in gear (not P or N) when the car wasn't warmed up. These issues all resolved.
Old Aug 19, 2023 | 09:07 PM
ThaoVue's Avatar
2008 Mercedes Benz C300 4matic
All fixed.
What do I Google search to buy distribution blocks ?
Old Aug 19, 2023 | 09:09 PM
ThaoVue's Avatar
What are the part numbers for c300 please 🙏
Old Aug 20, 2023 | 08:09 AM
JettaRed's Avatar
Veteran: Army
Did you read the previous posts?
