Tools kit, DIY projects advices
I'd like to have 2 sets
1) must have / most used tools
2) must have / less frequently used tools
I'd really appreciate your help and advices. And if you have links I'm hoping to find as much as possible online since here in Québec Canada it ain't always easy having to fighting bears and mooses just to go shopping 😂🤣👍
a set of metric sockets with ratchet handle in 1/4" and 3/8" sizes..1'2" drive can come later.
1/4" to 3/8' to 1/2' adaptors, plus 3", 6", 12' extensions. 3/8' swivel adaptor, spark plug sockets (thin walled in your size)
a set of Torx female/male sockets, again 1/4" and 3/8".
metric box/open wrenches,6mm to 19 mm to start
needle nose pliers, wire cutters
3 lb sledge hammer
Harbor Freight priced torque wrench, 1/2' drive
Multi insert screw driver with Phillips, slot, hex bits.
A decent LED flashlight
PB Blaster penetrating oil, oil change catch basin,
https://www.princessauto.com/en/catalogue
Canada's equivalent to our Harbor Freight...decent quality and a better price point.
Somewhat of a starting point...Good luck and Have Fun.
More specifically, most often used.
1) most used sockets/ open end wrench
2) most used torx
3) most used trim removal tool4) most used else 🤭
also products like break cleaner, lock tight , engine oil, what other liquids?
Also why a 3pounds beater? 🤔
