W204 folding mirror error
Old Sep 23, 2021 | 01:20 PM
Tord's Avatar
C-class w204 2009 204.246
Hi!
The folding function on my side mirror, right side, has stopped working. I know it is the folding motor itself, because the mirror makes a little ticking noise, so I know it gets power. I've concluded that the simplest thing is to just replace the whole unit, but I can not find a replacement with the same part number. So my question is, does anyone know which mirror with a different number can fin my car?
original part number A2048103616.
my car is a 2009 model, with the face-lift mirrors.
Thank you!
Old Sep 23, 2021 | 06:49 PM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Hi, my car had that problem from new, they replaced the mirror eventually just before out of gurantee, there was an issue, not sure if it was large enough to document then.(2008)
Old Sep 24, 2021 | 08:06 AM
Marcil802's Avatar
C300 2010 4matic
Originally Posted by Tord
Hi!
Thank you!
Hey, I'm a little bit confused about the question. Correct me if I got it wrong. I copy pasted your part number, and I found tons of passengers side mirror. From part retailers to eBay, and even in AliExpress. If for some reason it doesn't work for you. You may search for" W204 rear view mirror facelift"
you should find what you need searching with those keywords.
Let me know 👊
Old Sep 28, 2021 | 08:30 AM
Tord's Avatar
Let me know 👊
'Hey.
Thank you for taking the time. When i searched it, I didn't find any of those you did. Don't know why but i only found Russian retailers.
What I ended up doing was buying a part from that was pretty similar but with another part number, and then i rearranged the wires.
It appears that a lot of the different types of mirror asseblies got the same basics, but is wired a bit different.
Thanks for your help!
Old Sep 28, 2021 | 08:32 AM
Tord's Avatar
Hi,
I fixed it by swapping it out with a new one from ebay.
