New Alternator problems
Got New alternator and after 2months star getting red battery indicator every couple of days, so i got new alternator again. And start play funny games again after 1month, rmp slightly jumping up and down for little time. voltage at the moment 12.6 after 10-15s jumps to normal over 14v. Battery is good. Alternator with new voltage regulator. Any ideas what's wrong? Thanks in advance.
What you particularly don't want is anything near 12.3v or below while driving.
Let me ask you...:
Why do you keep replacing your alternator ?
How many batteries?
Any current scanned faults ?
I thought i got faulty alternator at the first stage. Warranty gives me new one, and now start do it similar things as the another.
No faults.
Usually most cars will be 13.8 - 14.4 volts with engine running.
I think if you are seeing something outside this with engine running I would get it checked out with a scanning device to see if there is any fault codes associated with charging.
Positive AMPs mean battery is charging.
Negative AMPs mean battery is discharging ie. paying for the show!
12.6V is called FLOAT voltage, it's enabled so ALT keeps supplying 100% of car power but without overcharging lead-acid battery when it's already fully charged.
Voltages from 13x to 14.xV are used to charge battery under BULK and ABSORPTION rates.
More is NOT better!
Alternator voltage is dynamic, not static... it keeps adapting to match your car's demands, much like a CTEK battery charger simply does.
If at anytime during driving the voltage swings below 12.6V like 12.3... 11.x or lower: that's trouble around the corner.
Pay close attention to voltage once the battery is charged up and ALT exits 13xv/14xV.
More is NOT better!
11.6V with engine running confirms a voltage issue. How many Amps??
Any picture of instrument cluster??
TESTING:
Does turning Headlights:ON gets you a voltage near 13.5v or no difference at all?
Are you getting a good stable voltage (13...14V) with the alternator control plug disconnected?
When i turn headlight on makes no difference.
Your battery has been charged full recently, right?
Disconnecting alternator plug should command the ALT REG to output internally controlled voltage. (Regulator is quite smart on its own with an internal Amp measure).
While under your car... check the fat GROUND STRAP TO CHASSIS has clean electrical connections (not rusted/oxidized)
