Time to change the starter - need DIY tips
So, I figured it was the battery and replaced it but same thing. So, that rules out the battery and alternator. I replaced coil packs and plugs 35k miles ago.
I believe it's starter and planning to do it.
I looked around but did not see many youtube stuff.
Any advice or suggestions would be appreciated.
Any recommendation on the starter itself? All I see are rebuilt. If I get it from the dealer I may get a brand new one or no?
Shop around for best price new starter.
ie
https://www.ebay.com/itm/18474509204...QAAOSwyIleXlNd
I removed all plugs, cleaned out everything and installed new plugs. I will check it again in few days. If there is oild again I will have to replace valve cover gasket and spark plug gaskets.
Now I am doubting if the starting problem was really the starter or one spark plug submerged in oil issue.
I, too have some oil in a couple of spark plug holes and have a replacement valve cover & spark plug gaskets on the shelf waiting for replacement at the next oil change. It's not likely that a single spark plug would cause a no start but you can temporarily unplug the coil from this plug try to start the engine.
I tried brand new Interstate battery yesterday and that did not help so I figured it must be the starter, while checking the health of the plugs I came accross the oil in spark plug. I will check again in few days for oil and meantime I will see how the starting is behaving.
In the thread here, poster NZ-Merc mentioned he got the starter from the dealer.
I will get starter tomorrow, not sure online or local place and will try to work on it next week end.
I brought my new starter from an on line store which specialised in Bosch parts not a Mercedes dealer, the local Mercedes dealers in New Zealand are very expensive for parts and do not offer any discount.
The cost of the new Bosch starter was just under 1/2 price of the Mercedes replacement starter from the dealers.
If you can work out the p/n required try ebay etc
This is the site I use to work out p/n then I go searching on line for best price.
https://www.ilcats.ru/mercedes/?language=en
Just a FYI, my Mercedes starter just suddenly died while my wife was away on a drive I got the call and had to arrange flat bed tow while I was at work, I think you want to avoid that situation if in doubt replace the starter don't look back.
I could hear the starter make 1 click sound and split seconds later another click but no start.
I tried thru out the day to start up so that I can put that on the ramp, I prefer working with ramps than jack stands, I don't have any jack stands but I won a floor jack.
So, went out in the evening and bought a set of jack stand.
I also ordered the starter from German auto parts. Good thing they have a warehouse in GA so I will get it tomorrow, hopefully.
I had this issue with my Acura years ago but it did start up after 10+ tries.
Starter just clicks. All dash lights turn on.
So, I turned the key yesterday and put the car in N position to move backwards to make room for jack stands.
Today I tried to start but just click from the starter, no start. But, now the car won't shift gears anymore.
Am I still looking at starter, battery, or some voltage issues?
I think all the failed tries put the car in limp mode?
If i have to do it again, it should not take more than 30 min. It take more time to jack up and get all the tools together, lol.
