2012 Mercedes C250 P0705 error, transmission probs
I took my Merc to the dealer after a check engine light and they read a P0705 code aka selection range sensor fault. They also read a Y3/8n4 aka fully integrated transmission control unit fault. Under this line item, they brought up the range sensor in the valve body having a high resistance. Has anyone experienced this issue and know where to look first? I’ve been reading that there can be a few different issues related to this code and I was hoping to narrow down what I need to take apart!
Symptoms include:
RPM staying higher than usual on the freeway
Loud humming when up to speed
Occasional shifting up/down at odd times. Also, semi automatic +/- is not working.
