Rotary Thumping Sound Rear of 2012 C300 4Matic
I have a rotary continuous thumping sound coming from the back of car. It's most pronounced when starting to drive from a stop or slightly more noticable when backing up and turning. When driving it sounds like I'm driving over the expansion joints on a concrete slab highway. Thump - thump - thump etc... ad nauseum. I checked the main drive shaft U-Joint and it seems perfect visually. I suspect pinion gear pin in the differential or CV Joints on the rear wheel drive shafts. Any thoughts of similar experences. Engine runs like a swiss watch and the transmission shifts beautifully.
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,930 Likes
2017 GLE350 4MATIC
Driveshaft center bearing or transmission mount or propshaft u-joint.
Terrytown (12-08-2021)
chassis (12-08-2021)
I suspected the prop shaft U-Joint and as painful as it is I may replace both. When I back up while turning left out of the garage it appears to be more distinctive. So left rear is more questionable. I will definate look at the flex disk and the center drive shaft mount bearing. Thank you all for your input.
