fender bending
Old Dec 24, 2021 | 08:06 AM
viisix's Avatar
MB W204 C280
fender bending
so my fender just bended like outwards if you look from cars view and I haven’t seen anyone else who have had the same issue so anyone here can give some recommends how to start bend it back to original form?
Old Dec 25, 2021 | 07:24 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
It may be best to replace your C Class with an off-roader or 4x4 as I think the fix to the car is new fender but the problem is the usage.
Old Dec 27, 2021 | 10:12 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
What size tire do you have ? Many people have put too tall of a tire and crack their fenders. You cannot go over 225/45/17. A 225/50/17 tire will bottom out on a pothole andcause this issue.
Old Dec 27, 2021 | 11:15 PM
viisix's Avatar
MB W204 C280
ha you are funny, but once you drive everyday in dark and bad condition gravel road you will see there can be new suprises everyday
Old Dec 27, 2021 | 11:20 PM
viisix's Avatar
MB W204 C280
I have 19” rims and remember having 235/35 tires on them. still plenty room to fit though. i saw from tire that it took a small piece from it but thats it so I’m pretty sure that it was bcs of that one hole in the road
Old Dec 28, 2021 | 12:02 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Plenty of room when the car is sitting on level ground may not be plenty of room when the suspension is at maximum compression. The 245/35R19 tires are 0.5 inches taller and 0.39 inches wider than the 225/45R17 tires. I’m sure it was the pothole, but that small difference in tire size may have been just enough to cause interference with the fender. I’ve driven my W204 off-road on my undeveloped property in a place better suited to US pickup trucks and never had this problem with standard tires.
Now on to how to fix. I’m not trying to be sarcastic or funny. The fender is not kinked or crumpled, so you may have some limited success by placing one of the floor mats between the fender and a sturdy 2 foot (60 cm) board and hitting with a 4 pound (2 kg) mallet. No guarantees here, though.
The damage does not look severe, so a competent auto body shop probably has equipment that can restore it to near original shape for a reasonable price. Good luck.
Old Dec 28, 2021 | 12:50 AM
235/35/19 has a diameter of 25.5", if they are winters, it might be even more. The stock diameter with 225/45/17 is 25" and the optional 18s with 225/40/18 is 25.1". You are talking about optional C63 tire sizing and the amg's have wider fender to prevent this issue.
Old Dec 28, 2021 | 03:26 AM
viisix's Avatar
MB W204 C280
I'm pretty confused about how this even happened to be honest. I can admit that last summer I drove like maniac over some holes which I didn't see but got zero damages. And I have pretty hard suspension that doesn't really give up that much. What comes to fixing it is that will change it for a new one that costs less than going to repair this as you can't use PDR-fixing anymore.
Old Dec 28, 2021 | 03:39 AM
viisix's Avatar
MB W204 C280
Yeah I know we discussed these diameters with the tire dealer and ended up with our calculations that I don't need to go to 235/30/19. The biggest worry was that are 19" too big that I can't rotate my wheels fully. Actually found a picture from last summer when I got those wheels.
Old Dec 28, 2021 | 04:07 AM
Odd Piggy's Avatar
… you can't use PDR-fixing anymore.
I’m not familiar with the term “PDR fixing” and why it can no longer be done???
Old Dec 28, 2021 | 12:32 PM
viisix's Avatar
MB W204 C280
It’s a way to fix any bendings in your car with heat and different tools but to be able to do that your paint must be okay.
Old Dec 28, 2021 | 06:28 PM
Odd Piggy's Avatar
Paintless Dent Repair. Where was my head ???
Old Dec 28, 2021 | 07:36 PM
cvx5832's Avatar
325Ci, 325Cic, C300
This can still happen with spec tires. Particularly if your car is loaded and you brake while attacking a 90 degree left hand on ramp. It pulls the fender out like you see here.
Old Dec 29, 2021 | 12:54 PM
viisix's Avatar
MB W204 C280
Yeah I'm aware of that. I expected it happened on that one curve close my house where is a big hole while turning into the left
