Cylinder Head Cover Gasket
2020 C300, 2013 C250, 2000 Boxster S
Replaced the cylinder head cover gaskets and spark plugs on my 2013 C250 last week. Oil had been leaking slowly for some time but was becoming more noticeable. The gasket around each coil had failed and all of the spark plug holes were filled with oil. The old gaskets were like hard brittle plastic and broke apart during removal. Project was straight forward and took a couple of hours. Most of the time was spent cleaning the gasket surfaces, coils and removing any oil from the coil and cover bolt holes. Had a nice big smoke screen on the first engine start from all the oil draining into the cylinders when the spark plugs were removed!
2013 C250 188,270 miles
I have done this a month ago and in the process I managed to break the right side chain guide. I rigged it to stay in place and put everything back in with new gasket and seals.
I will redo it soon to replace the broken chain guide, so I will be doing all new seal and gaskets again along with chain guide.
Man, I was so careful this time and thought I had finally successfully completed a job on this vehicle without breaking something or having to buy additional unexpected parts.
