No power to fuse box
The marked areas with blue arrows on the image below have power but not the blue circles
Is there a way to check the fuses in the prefuse without opening the box? may be from the red wires leaving the box in the bottom.
I have opened the box and found a bout 5 fuses on the same white metal plate and they are not separate fuses and when I was checking them for continuity turned out that all have continuity. I do not know if I did it right or because they are attached to the same plate...
