Repaired side mirror not operating correctly
Old Feb 7, 2022 | 09:47 AM
Apesbrain's Avatar
1999 SLK230 & 2019 C300W4
My wife hit a recycling bin with her right-side mirror. I was able to get a replacement glass and glue/reassemble the housing. It works for the most part (alignment motor and blinker light are operational), but no longer tilts down when transmission moved to "Reverse". It moves, but not in the right direction. Is there anything a mechanical novice can do to correct this? Thanks.
Old Feb 8, 2022 | 11:19 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Stating the obvious, but make sure the adjustment button for the passenger mirror is pressed. If the driver side adjustment button is pressed, the mirror does not automatically adjust in reverse.
Old Feb 8, 2022 | 11:51 AM
Apesbrain's Avatar
Ok, I'll check on that. When the transmission is moved to "Reverse" the passenger mirror moves, but no longer in the correct direction. It returns to original position when transmission moved out of Reverse.
Old Feb 8, 2022 | 10:00 PM
Odd Piggy's Avatar
I think we’re getting somewhere! If it’s moving at all the switch is in the right position and it just might be OK.
Try this:
Shift to Reverse.
Try to adjust the mirror with the control pad to where you want it after it stops in the wrong place.
Is there enough adjustment?
If yes, shift back to Forward.
Does it return to the normal setting?
If yes, all should be OK.
Try Reverse again just to be sure.
If it’s not working, one of the cables (I think there are 3) that moves the mirror may be binding or may have become disconnected. The next move might involve removing the mirror again and/or going behind the door trim panel. These things are pretty simple.
