Front End Height - 2012 C250 Sport
Old Apr 29, 2022 | 07:26 PM
BMuehlberger's Avatar
2012 Mercedes C250
Hi.
I replaced 2 upper control arms and the front struts on my 2012 C250 Sport.
The front end is now riding high.
Here is a pic of the current height. I didn’t take a pic prior - so I’m wondering if anyone has a similar model and can give me some measurements for stock height/clearance?
Ground to Fender: 26 3/4” inches
Top of tire to Fender: ~2” inches
If anyone has an idea on cause that would be great. I tightened the control arms with front end loaded on the new struts.
thanks
Old Apr 30, 2022 | 11:08 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Here are the measurements from my 2013 C250. I do have 198K miles on the car with the original components so the total height and the distance from the top of tire to the fender may be less than with newer suspension.
Ground to fender: 25 in
Top of tire to fender: ~ 1.25 in
Maybe check that the springs are fully seated in the spring perches on strut mounts and that the struts are fully seated in the fender mounts?
Old May 5, 2022 | 02:37 PM
Gazwould's Avatar
S204 C250 CDI Sport
Has the procedure of resetting the ride height of the bushes been performed ?
Old May 6, 2022 | 12:13 PM
C0d3Sp4c3's Avatar
2013 C250
Just for you....
Here's my 2013 C250 Sport with stock AMG 18" wheels and staggered setup (Front= 225x40x18, Rear= 255x35x18). Noticed the date code on the tires? The car was purchased brand new in late 2012 and so far it has 24.8k miles on it. Everything is stock except for the OEM battery which was replaced 2 months ago.
Old May 6, 2022 | 12:32 PM
alynch's Avatar
Should have pointed out mine are non-AMG wheels 17" wheels with staggered setup (front - 225/45-17, rear - 245/40-17) so the comparison may not be valid.
Old May 7, 2022 | 09:42 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Did you purchase the struts for a sport model or a standard model?
Old May 7, 2022 | 09:55 AM
JettaRed's Avatar
Veteran: Army
You should check the tires for dry rot. 10 years is a long time. You may need to examine the inner side of the tires. I had a 2004 SL500 that I bought in 2017 and was checking under the car for something when I noticed huge cracks in the inside sidewalls. Checking with the person I bought the car from, she had the tires replaced about 6 years before. The dealer said 6-7 year is about the maximum safe age of a tire.
