help with whining noise
Old May 19, 2022 | 09:19 PM
1iwilly's Avatar
2009 c300
Exclamation help with whining noise
for the past few months, my 09 c300 has a whining noise coming from the front of the engine i thought it could be the belt tensioner pully i replace it but it didn't fix the noise problem, if i take the belt off the noise goes away i spun the alt manually but no noise same with ps but as you hear the whining it almost sound like the ps pump
Old May 20, 2022 | 06:49 AM
alecmascot's Avatar
W204 C220CDI 2011
Did you check the belt idlers ?
Old May 20, 2022 | 08:03 AM
1iwilly's Avatar
2009 c300
Exclamation
Old May 20, 2022 | 09:36 AM
alecmascot's Avatar
W204 C220CDI 2011
But aren't there two idler pulleys in addition to the ancillarys and the tensioner ?
Old May 20, 2022 | 11:19 AM
1iwilly's Avatar
2009 c300
Exclamation
i have been under the hood in a while i drive a truck out of state I'm
home temp want to try and fix this issue yes there are 2 other idle pulleys and 1 belt tensioner
Old May 20, 2022 | 11:23 AM
alecmascot's Avatar
W204 C220CDI 2011
So check the bearings on the idlers. The grease dries out and the bearings wear out.
