Absorber container?
Old Jul 26, 2022 | 10:35 PM
Blurrat120MPH's Avatar
2012 c300
Absorber container?
I just purchased a 2012 C300. So I bought the car with front end damage and in doing so I am having to replace the front clip and some damaged hoses and what not. I came across something which is called the absorber container located above and back from the left drivers headlight and it connects via hose to a part above the power steering pump above, and slightly behind, the 2 pin plug is broken and I can't identify the part in order to buy the proper pigtail for a repair. I was hoping for some help in identifying this. I have attached photos of the part. Thank you in advance.
Old Aug 24, 2023 | 01:11 PM
rozcco's Avatar
merz c350
Purge valve
that’s the purge valve
Old Aug 24, 2023 | 06:39 PM
TimC300's Avatar
Try this, should link to parts diagram sheet. its for my 2010 C300 but part 3s may be the same
http://truckmall.ru/epc.aspx?mid=10519&subcatid=2798
Old Aug 24, 2023 | 06:42 PM
TimC300's Avatar
That connector may be part# 2035453928 "HOUSING SHUTOFF VALVE ACTIVATED-CARBON FILTER 2-PIN SLK2.8,Y58/1".
The purge valve should have the part# stamped right on it.
I find the Mercedes dealer parts dept has parts like this for a good price. The one near me I usually have to order the parts and wait a few days, they make me pay first. or maybe check ebay, may find a used purge valve with the hoses and connector still attached for a cheap price.
Old Aug 24, 2023 | 07:49 PM
TimC300's Avatar
Parts Diagram:
Pay no attention to the markings, i was looking up parts for myself previously.
