Transmission Fluid Replacement
Old Sep 8, 2022 | 01:16 PM
amoffitt's Avatar
C350
Hey guys,
I am wanting to replace the transmission fluid & filter in the car. Typically I buy the Mercedes fluids from the dealer, I wanted to know if anyone has done a fluid and filter change with any of the kits from FCP Euro and if so, were you satisfied with the fluid provided?
I was looking at this kit to be exact:
https://www.fcpeuro.com/products/mer...rlysk1#reviews
Old Sep 8, 2022 | 01:55 PM
Just204's Avatar
Mercedes w204 4matic sport
Those brands are good ones so your probably fine. Have you done this before? Reason I ask is that Mercedes’ updated the pan design so the overflow tube is designed to go with that. Personally, I would only use OEM on this and maybe aftermarket bolts, OEM bolts are $5 a piece!!!
Old Sep 8, 2022 | 04:13 PM
amoffitt's Avatar
C350
I have never actually done this on the car. The car seems to have a bit of vibration on acceleration in certain gears and the Adaptation Values showed the 2nd and 3rd gear range to have some issues. The car has 131K miles on it and the transmission fluid has never been changed. I figured that might resolve my issue hopefully. I might need to look at the valve body and see if there is any issues with O-rings there. I did call my Mercedes dealership and they wanted around $45-$50 a quart for the transmission fluid for my car. I thought that was a bit steep.
Old Sep 8, 2022 | 04:50 PM
Just204's Avatar
That price is theft. Here; https://www.fcpeuro.com/products/mer...s-002989060309
at your mileage it’s risky changing the fluid the first time but you can change it. The shaking could be other things though.
Old Sep 9, 2022 | 12:04 PM
amoffitt's Avatar
C350
Do you know if Pentosin oil is the same oil the Mercedes sells but without the Mercedes bottle and label?
Old Sep 9, 2022 | 12:33 PM
Just204's Avatar
that I don’t know, but aftermarket oils are usually designed to work with a range of different makes/models. They are not specific to our car, there is also 2 different fluids and our transmission is real sensitive. For a bit more money it’s worth it to me for the piece of mind.
Old Sep 9, 2022 | 01:06 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Pentosin may or may not be what is in the Mercedes bottles.
What is important is:
Pentosin ATFs are approved on the Mercedes BeVo.
Pentosin 134 is approved on sheet 236.14 for vehicles with 722.9 transmission up to June 18, 2010 production date.
Pentosin 134 FE is approved on sheet 236.15 for vehicles with 722.9 transmission from June 21, 2010 forward.
The fluids are not cross compatible. You must get the correct one. 236.14 fluid is red. 236.15 fluid is blue.
Old Sep 9, 2022 | 01:58 PM
meazz1's Avatar
C250 2013
For my C250 2013 sport, I used Pentosin from FCP, but I got the 5 liter+1 liter bottle. my car olny needed 6 liters. It's been almost 40k miles now since the fluid change and so far no issue. I am planning to do it again soon.
Old Sep 10, 2022 | 07:48 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
I used Fuchs Titan ATF 4134 from memory, the important thing is the oil spec for your transmission.
Old Sep 23, 2022 | 02:52 PM
amoffitt's Avatar
C350
I went ahead with this kit from FCP Euro:
https://www.fcpeuro.com/products/mer...em-7229erlysk1
It seemed to resolve my problem. The fluid that came out was black/brown. I assume it had all 131K miles on it. This stuff fixed up the transmission back to 100% it feels like and the car drives great again. Thanks for the assistance and input guys.
Old Sep 23, 2022 | 05:35 PM
meazz1's Avatar
C250 2013
How many qts did you need? How did you measure fluid temp?
Old Sep 23, 2022 | 05:53 PM
amoffitt's Avatar
C350
I ended up using right around 8.5 Liters I believe. I drained the fluid and took the pan off of the transmission one evening. I let it sit and drain overnight and get as much fluid out as possible. The next morning I put everything back together and filled up the transmission with a pneumatic system. The fluid started going back in the car at 30c and with an Autel diagnostics device let the car warm up to 40c. At 40c I checked the fluid level in the pan by removing the fill mechanism but nothing draining out. So I filled it up a little bit more and checked again. Once I saw that fluid was draining back out then I knew it was full. A little bit more went into the transmission after just to be sure but it was a very small amount of fluid. After that I took it out for a gentle drive just to make sure that everything was solid. I still believe I have some dirt running around the transmission but this new filter should clean that up after a few thousand miles.
Old Sep 23, 2022 | 06:54 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Glad you got it done. How's the acceleration vibration?
Old Sep 23, 2022 | 07:37 PM
amoffitt's Avatar
C350
Thanks. Acceleration seems to be back to normal. I do not feel any vibration at all anymore. I guess I did not realize that the fluid could make that big of a different. (Although I should have)
Old Sep 24, 2022 | 12:39 AM
cvx5832's Avatar
325Ci, 325Cic, C300
Thanks for the feedback. Glad it's sorted out now. Did the fluid come out black? My 110K to 170K OCI still came out red so I was thinking going for at 80K OCI on this fluid charge.
Old Sep 24, 2022 | 09:23 AM
amoffitt's Avatar
C350
Yeah, the fluid that came out for me was black/brown. It almost smelled like burned motor oil.
Old Sep 25, 2022 | 08:42 AM
Xzero's Avatar
2022 EQS 580 4MATIC Sedan, 2010 C-Class C350 4MATIC
For next time or anyone else looking this up, I have a great maintenance thread that covers all of this:
https://mbworld.org/forums/c-class-w...ce-thread.html
