C250 2013 Coupe, what's the brake pads thickness? is 1mm ok?
Old Sep 30, 2022 | 08:05 PM
st0's Avatar
st0
C250
Question C250 2013 Coupe, what's the brake pads thickness? is 1mm ok?
Never replaced brake pads since day 1, and got about 72000+ miles. My last dealer maintenance told me front pads is 1mm and back is 8mm. Should I replaced it now? What's the original pads thickness? so that i can estimate how long i can drive till Warning light show up.
Thanks,
Old Sep 30, 2022 | 08:47 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Usual minimal thickness is 3mm for change out but most will change at 4-5mm since ,when this thin, the wear rate is accelerated (increased heat) Did your Dealer not really press you to change the 1mm fronts ? Original pad thickness for the fronts vary from make to make..10-12mm is new. IMHO you should get new fronts NOW.
Old Oct 1, 2022 | 12:08 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The next thing you’re going to hear without warning is grinding of the pad backing plate against the disc. C-Class non-AMG cars only have wear indicators on the inboard pads of the right front and rear wheels. Pads rarely wear evenly. 1mm pad thickness is borderline dangerous.
