All My Lights Came on At Once
Old Oct 3, 2022 | 05:39 PM
Mymoney#1's Avatar
c250
Hey Guys I have a 2014 Mercedes Benz c250 and all my lights on the dashboard came on check engine and check the owners manual came up on the dashboard. I got a new battery and now I only have one code that's popping up P2610.
Does anybody know how to reset it or what I should try before taking it to Mercedes? I recently had the Valve gaskets and Entire Assembly replaced.
Old Oct 3, 2022 | 06:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Oct 3, 2022 | 11:16 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
P2610 is a generic drive cycle detection error. Has the car been driven for at least 30 minutes then turned off for another 30 at least twice? After that it should go from active to stored where it can be reset. After some number of drive cycles, I have heard that it clears without reset. If it remains active a scanner that will display real time data will be needed to see where the failure is. An Independent MB shop should be much less expensive than a dealer.
