Wheel Fitment.
Old Oct 25, 2022 | 02:12 PM
tkolody's Avatar
2013 C300 4MATIC Sport
Wheel Fitment.
I apologize, I tried to find a threat containing this information however no one seemed to have precisely what I was looking for.
I have a 2013 C300 4Matic sport with the 17" staggered setup. The suspension and brakes are completely stock. Unfortunately, since I discovered a crack in the OEM rim from the previous owner, I need to buy new rims.
I was looking at doing these rims: https://www.anoviawheels.com/buy-whe...spension=Stock
I was hoping to run 18x8.5 +35 squared with 255/35R18 tires
Do yall think that I would have issues with rubbing/clearance in the front?
Old Oct 25, 2022 | 03:51 PM
AAIIIC's Avatar
2014 C250 Luxury
There are multiple threads about wheel/tire fitment, with lots and lots of pics and examples.
https://mbworld.org/forums/c-class-w...ts-wheels.html
https://mbworld.org/forums/c-class-w...on-thread.html
https://mbworld.org/forums/c-class-w...el-thread.html
I think 255s up front will be an issue, but see what you find in those threads ^^^^.
Old Nov 4, 2022 | 11:08 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Max you want on 8.5" rim at front is +45 offset. It will poke out way out from the fender if you go with +35. If you will go with 8.5" rims on +45 offset wax tire width should be 235. If the other rims are in good shape try sourcing a replacement of the OEM rim.
