Lose sensor
Old Dec 1, 2022 | 04:50 PM
Marktee's Avatar
2012 C250 Turbo M271 EVO, 08 X3, 08 328i
Lose sensor
Is it normal for the sensor on the thermostat to be loose like in the image/clip. I just replaced the thermostat and the gauge is fluctuating. The other sensor is more solid but could not find a way to tighten the loose sensor. Is it possible the fluctuations in the gauge from this lose
https://photos.app.*******/AGyC8FHuoGQ9k1tP8
Old Dec 1, 2022 | 11:51 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Can’t open your pic, but no, it’s not normal for it to be loose.
Old Dec 3, 2022 | 02:41 AM
Marktee's Avatar
I was able to upload a clip of the moving sensor on Benz world forum but don’t know why couldn’t post it on this forum. I have tried everything iPhone suggested to check and do
https://photos.app.*******/wXnvqqWPXQbHrRoh6
Old Dec 4, 2022 | 04:55 PM
Marktee's Avatar
https://photos.app.*******/8WCsfj6Zydb43pQY9
Old Dec 4, 2022 | 05:17 PM
Marktee's Avatar
can you replace the stars in the link to “goo.gl”
whenever I submit the link, the website changes the middle of the link to stars. I plugged the “goo.gl” instead of the stars and was able to play the video
Old Dec 4, 2022 | 06:31 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
There are two spring clips that hold the two sensors in place on the thermostat housing. You might want to check that these are fully pressed home.
Old Dec 4, 2022 | 08:27 PM
Marktee's Avatar
I will check the grey sensor clip in the morning. the black sensor seems to be tight in place and barely moving. Thanks
were you able to check the 8 second clip?
Old Dec 4, 2022 | 08:28 PM
Marktee's Avatar
4
