Thinking about pulling the trigger on this 2011 C300 4-Matic (for a winter beater).
Old Dec 24, 2022 | 05:20 PM
moosaud1998's Avatar
2019 BMW 540, 2017 Mercedes-Benz E300 4-Matic
We just took the car in on trade Friday. Runs and drives well. Has a slight lifter tick to it. The body is in pretty good shape. Looks like it was in a front-end accident (The hood's paint is somewhat peeling). Has 4 brand-new Goodyear tires. Obviously, I work for the dealership so I'd be paying $500 above our cost +TTL. Anything I should look out for? Doesn't seem to leak oil as I didn't smell anything when driving it. Didn't see any oil under the hood. But, I did take the oil fill cap off and the oil was super dirty. Not sure when the PO changed the oil but I'll probably have the tech at my job put some anti-friction stuff in the motor when he changes the oil. I'm going to have the service department do a used car inspection to see if there is anything major I should be worried about. I won't be keeping the car for longer than a year. The only thing that I am iffy about is the carfax says, "Exceeds Mechanical Limits". Not sure what that means but the miles seem to add up when you look at the service records on the carfax. Link to Carfax: https://connect.carfax.com/dir?key=...2eOUmpoZcI6NfGj-7T7-8vTmLUmqamqrjNAlqur2Krq5E
Any clue as to what that means? Maybe a mistake on the DMVs part? Cars got 172k miles
Old Dec 25, 2022 | 12:53 AM
cvx5832's Avatar
325Ci, 325Cic, C300
The M272 can go a long way, I have 202k on mine. That said I got the impression around here that it's the transfer case to worry about.
Old Dec 25, 2022 | 11:09 AM
what's there to worry about in terms of the transfer case? I didnt get to drive it to far. I wanted to take it home lver the weekend but we havent changed the oil yet. I don't want to take it to far with dirty oil.
Old Dec 25, 2022 | 10:17 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
“Exceeds Mechanical Limits” refers to the odometer. In this case, that’s absurd because the car would have to have a million miles or more on a 6 digit odometer for this to be accurate.
Old Dec 25, 2022 | 10:54 PM
Exactly. So, im assuming the DMV check marked that by mistake. I hope there is nothing major wrong with the car.
Old Dec 26, 2022 | 06:58 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
This sounds like a car that should not be more than 2-3k and should not have any money dumped into it. I’d not be so worried about driving with the dirty oil because the previous owner has probably not changed it in 20k miles. It sounds neglected and what’s done is done. As you know there is nothing more expensive than a cheap Mercedes. So we can better help, perhaps list out your budget and goal. Do you only want it for a year or only ultimately think it will last for a year to get you by, two different ways of thinking. Good luck. Nice cars when maintained well.
Old Dec 26, 2022 | 07:22 AM
I was only going to use it during the winter and then sell it. I mean, if there's nothing major wrong (which I doubt), I might end up keeping it until it doesn't blow. For a winter beater, I did not want to spend more than 3k. This falls about 1k under.
Old Dec 26, 2022 | 08:40 AM
chassis's Avatar
2017 GLE350 4MATIC
Intake manifold?
I would not do as the OP proposes which is to buy this questionable car to own for a year with the hopes of not putting more money into it.
Old Dec 26, 2022 | 09:23 AM
Originally Posted by chassis
Intake manifold?
if I have to put $1k in it for it to last me more than a year, I'm okay with it. That's if I can get it for $500 above cost. If not, I'll pass
Old Dec 26, 2022 | 10:38 AM
Well, I peeked under the hood. Doesn't seem like it's leaking oil anywhere up top.
Old Dec 26, 2022 | 01:37 PM
I'm at 2800 with taxes and stuff. I just want to make sure it's no leaking oil underneath
Old Dec 28, 2022 | 09:45 AM
AAIIIC's Avatar
2014 C250 Luxury
Originally Posted by moosaud1998
I wanted to take it home lver over the weekend but we havent changed the oil yet. I don't want to take it to far with dirty oil.
Oil gets dirty in any engine once it's been run for a little while. Unless you saw visible metal flakes there's nothing to worry about.
Give it a thorough check underneath - https://mbworld.org/forums/c-class-w...-subframe.html.
Old Dec 28, 2022 | 11:38 AM
The oil was like muddy. When i took the cap off, the side of the motor by the timing chain was all muddy.
I passed on it. Seems like it's too risky
Old Dec 28, 2022 | 03:31 PM
Odd Piggy's Avatar
Muddy sounds like water in the oil. Regardless of where that came from, passing sounds like a good decision.
