Seat belt working, showing airbag error
Hello Guys, I have a c204. It was in a crash. 3 sestbelts were locked. I replaced the two rear and it now works, but the front drivers side seatbelt started working normally. The motor works and everything is fine. I now went to clear the codes and I was unable to clear the front drivers side airbag due to the seatbelt. It had the crash still registered. Is there anything I could try without taking the seat belt out and replacing it? Ill do it if I have to, I just want to try everything before it.
Thanks, I tried to use the least words I could.
You not making sense. Either the seat belt is faulty or the sidebag. Tell us the exact fault text. You need to repair the fault clear the codes and the light will go out.
