Transmission codes
i have a 2010 c300 4matic. Have codes u0101, u0001, u0002, car drives fine , only symptom is when i stop at a red light i feel something like a tap where the transmission wants to go forward. Am trying to figure out where the tcm module for can communication is located, before it reaches the valve body inside the transmission. I found some moisture in the trunk on the right side by the fuse box. Checked connections and all are good. Fixed the small water leak. Does that box have anything to do with the tcm bus? Am sure this is the sam box.
just says unable to communicate with the tcm. I checked the connection to transmission and it has a bit of oil on it so i unplugged it and cleaned it to see if it will make a difference
i have xentry, let me see if i can get more info trom it. Weird thing is that it drives all day with no jerking or anything and only has 123k, hard to believe the electronics have failed on the inside of the transmission . This means removing the valve body correct?
