Coffee cup ☕️
Old Feb 22, 2023 | 09:02 PM
Nates's Avatar
2013 c250
Exclamation Coffee cup ☕️
So my 2013 c250 has the ABS light and engine light on, it’s reading c0031, I just changed the front left speed censor and erased the engine code, i tired but couldn’t erase the ABS code. The engine light came back and the ABS light is still there. Also sometimes the ABS light will go off and the coffee cup with come on to replace it, and the ABS light will come back and the attention assist is go away, what’s going on here?
Old Feb 22, 2023 | 10:29 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Either the new sensor is faulty, the wiring harness is broken, or the harness is shorted. Can your scanner read real time data from the ABS circuit? That may help define the problem.
Old Feb 22, 2023 | 10:33 PM
Nates's Avatar
2013 c250
unfortunately I have a cheap obd but when you say harness do you mean the wires that are attached to the sensor or another part? I was thinking about changing the left and right sensors and seeing if the code jumps
Old Feb 23, 2023 | 01:48 AM
Odd Piggy's Avatar
When I said harness, I was referring to the sensor wiring anywhere. When it breaks, causing an open circuit, it is usually near the wheel.
Your idea about swapping left and right sensors is a good one. If the problem moves, then it is definitely the sensor. If it does not, then the problem is somewhere on the left side.
Old Jul 12, 2025 | 08:59 PM
yovenim's Avatar
just looking
Originally Posted by Nates
So my 2013 c250 has the ABS light and engine light on, it’s reading c0031, I just changed the front left speed censor and erased the engine code, i tired but couldn’t erase the ABS code. The engine light came back and the ABS light is still there for the Starbucks Menu. Also sometimes the ABS light will go off and the coffee cup with come on to replace it, and the ABS light will come back and the attention assist is go away, what’s going on here?
The code C0031 points to an issue with the left front wheel speed sensor circuit. Since you replaced the sensor and the ABS light remains, the problem is likely in the wiring or the connector. Check for damage, corrosion, or a loose connection. The engine light coming back suggests the issue wasn’t fully resolved. The attention assist and coffee cup icon switching on and off is normal when the system gets inconsistent speed data. If the wiring looks fine, the ABS module could be at fault. A more advanced scan tool might help pinpoint the exact issue.
