Water in passenger side
One of my headlight washer cover has come off. Is it possible for water to get into the chassis from there? Seems too far way but then who know what is connected where from the inside.
I removed the rear seat and partially lifted the carpet on the passenger side and saw standing water on there. During cleaning it I noticed a round black kind of washer. Out of curiosity I pushed it and it fell inside between the inside of the chassis and the outside of the chassis below. Have I made the problem worse because water can not get into this location. I didn't see standing water in that location but now that it is open in future water can get into it. What is that washer part and where can I buy it from?
Best would be to go to your dealer and get the part there. Based on your description, it is doubtful for anyone to know which part exactly you are looking for.
I have removed the carpet/seat. There are a couple black round plugs on the chassis from the inside. If I remove this there is another chassis part that is dark and is about half an inch below this with empty space between these two. I am wondering if I can remove the plugs because they trap water inside and keep the carpet wet. If water goes out of these holes will it still get trapped between the inner and outer part of the chassis?
Any issues with just removing the plugs?
After removing the carpet I still hear some sloshing as I apply the brake. Is this just gas tank, or is there pooled water in some other places?
Sunroof Drain pipe valve
