m276 water pump bolts
Old May 29, 2023 | 11:21 AM
Psyko's Avatar
w204 c300
the mercedes service procedure says to replace the water pump bolts when replacing the water pump. does anyone know the part numbers for:
1, the water pump to timing case bolts
2, the water pump cover to water pump bolts
3, thermostat housing bolts
Old Jun 6, 2023 | 07:29 PM
SobRogue's Avatar
C300 4Matic
It's strange that the bolts are not shown on the mbparts diagram, my best guess is:
1) the water pump to timing case bolts: -- Engine Water Pump Bolt 009-990-27-04
2) the water pump cover to water pump bolts: -- Water Pump Assembly Bolt 910143-006002
3) thermostat housing bolts: -- Engine Coolant Thermostat Bolt 910143-006002
They are listed as "Front Deflector Bolt" and "Bumper Impact Absorber Bolt" in the title, but if you read under the 'Other Names' section, it lists the names I mentioned above.
