2013 C350 zero electrical power *dead*
no history of any problems whatsoever. No accidents. Only ‘spa visits’ for its yearly check ups and new tires about 3 months ago.
Any ideas???? Please help 🙏
If it’s DOA, it could be the battery itself or a failed voltage regulator (it’s on the alternator). Both can be tested.
If it’s around 12.6 V the fun starts.
The battery monitor on the negative cable could be bad, or a lot of other things.
Check to see if you have power at the OBDII connector and scan for codes if you do.
I hope this may help you.
