Pulling the engine and trans
Old Jul 18, 2023 | 09:36 PM
2007mustang's Avatar
2003 Mercedes sl500 & 2012 C300 4matic
Have a siezed up engine in my 2012 C300 4matic sport. Putting another engine in next week. Anyone have any thoughts on any problems we may run into pulling engine and trans together? Also about splitting the block from the bell housing? Any hidden bolts? Will remove the oil pan and loosen the end and main caps to try to get it to turn so we can get the torque converter to line up so the 6 bolts can be removed thru the window. Are the 9 or so bell housing bolts the only ones or are there any from the block back to the B Hsing that have to also be removed? Any one do this and run into any special issues or special tools needed? THanks
