Out of gas...ran, now won't start
Old Sep 21, 2023 | 06:06 PM
dweb4's Avatar
S550 4-matic
So had a friend who ran out of gas in the 2010 c300 yesterday. So went to help put 5 gallons in the tank, drove to gas station put enough gas in to have half a tank. When started car it ran really rough. Cut car off tried to restart and continued to run rough. Turned it off and tried again now it won't start at all. Anyone have any of same problems?
Old Sep 21, 2023 | 07:32 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Either debris from fuel tank have clogged injectors or burnt fuel pump would be my guess
Old Sep 21, 2023 | 09:43 PM
TimC300's Avatar
Air in the fuel lines maybe. Try priming the fuel pump, turn the key on and off(dont turn the car over) for a couple times, like 5-6. Turn the key on for a few seconds then off, repeat. see if it starts then.
I would hook my scanner up to it also.
And check fuel pump fuse/relay. Think they may be in the trunk, but not sure.
Also, have you tried pushing down on the gas pedal when trying to start it? My car wouldnt start before after getting gas, I stepped on the gas pedal and it started finally.
