The car won’t Start 🥺
WRT the seatbelt error (B0050-13), there is a common problem with the C-Class seat belt buckle having a wire that breaks and you must replace the entire latch.
Is there a ticking sound coming from the steering wheel when you try to start it?
Did those codes show up after you cleared everything? How did that car run at all to get you home?
Are there really 200,000 miles on the car? Not to make you feel worse, but you now know to scan any used car before buying. The BlueDriver is good for that.
In my Operators Manual page 78 Starter Switch Positions section it says "The steering is locked when the Smartkey is removed from the starter switch". Above it it mentions if the key is left in the "O" position for an extended period it can no longer be turned in the starter switch and the steering is locked. Try that, see if the steering locks.
