Stuck intermediate shaft bearing
Old Oct 31, 2023 | 11:16 PM
Cesarek94's Avatar
c300
Hello everyone, intermediate shaft bearing was damaged needed replacing when removing intermediate shaft it came out with only the inside of the bearing the outer part its still stuck on the oil pan housing any ideas how to get it off?
Old Nov 1, 2023 | 04:15 PM
TimC300's Avatar
Off the top of my head a slide puller.
Old Apr 5, 2026 | 05:05 PM
FarmerGraham's Avatar
2015 GLK350, '96 Defender, 1986 XJ12, '68 420G, '66 E-type FHC
Hi. I am replacing my bearing at this time as well. I have not removed my shaft yet, it does not come out freely. Is it a splined fitting? I have been cautious trying to get it removed, and seeing yours removed gives me hope. Any insight would be greatly appreciated. sorry i dont have a solution for you to release yours, but i typicaly would use a bit of heat on the alloy to expand releasing the steel bearing. I have heard that this area can be a bit delicate so force is not recommended. Good luck.
Old Apr 5, 2026 | 07:44 PM
TimC300's Avatar
There is a retaining ring holding the bearing in place that has to be removed first. Then the shaft with the bearing should pull out.
Item 150 in the diagram below.
