W204 abs problem/ sensor multifuncion
Specifically a LAUNCH cReader Elite will help you well don't shot change yourself with a discount piece of kit.
You have intermittent random "X-Mas Tree"... I associate that with marginal electricals.
As in check:
- Alternator output: voltage ?
- Bad system battery: charge, drain ?
- Main chassis GND: oxidized strap ?
You said no code, that is fairly strange as these cars come with hard codes from factory... at any rate a good scanner will let you read LIVE MODULE DATA.
Hope this help you sort things out.
my car always jerks every first 20 km/h only.. after I start the car there are warnings pop-ups that say "1. Release parking break & 2. Front right/left malfunction, Consult workshop" After that it ran smoothly but sometimes the check engine warning lit up but sometimes its went automatically
I've taken my car to the diagnostics, and the following codes have shown up with the following faults. Any help or advice would be appreciated.
C180 BLUEEFFICIENCY EXECUTIVE SE , 2012 1.6 cc
P250513
The power supply at the input of the control unit 'combustion engine' has an electrical fault. There is an S open circuit.
P06DA00
Select 'Error codes / Events' menu item in control unit 'N3/10 - Motor electronics 'MED40' for combustion S engine 'M274' (ME)'. Then read out fault memory.
B1C1113
The NECK-PRO head restraint 'Driver' has a malfunction. There is an open circuit.
B1C1713
The NECK-PRO head restraint 'Front passenger' has a malfunction. There is an open circuit.
C41500.
Implausible data were received from control unit 'ESP®'.
C200200
The supply voltage of control unit 'N30/4 (Electronic Stability Program control unit)' is too high (overvolta ge).
B210F00
Input 'Circuit 30' has a malfunction. _
C115
Communication with the instrument cluster has a malfunction.
990915
The output for actuator motor 'Additional door lock' has a malfunction. There is a short circuit to positive or S an open circuit.
A10C17
The power supply is outside the valid range. The limit value for electrical voltage has been exceeded.
A10C17
A10C17
A10C17
Ive changed the battery to a newer one but no change
ive noticed with an OBD 2 sensor ( the alternator voltage ) when i cold start the car and drvie off the voltage drops to 12.5 volts , i have a feeling it could be related to the voltage regulator ??
any advise please
Replacing expensive modules blindly will not fix that. One single $10 relay would serve as perfect fix. I would not rush to swap ESP, ECU nor SAM.
You'll need the related schematic pages to trace that circuit to ECU.
As in check:
ACTUALLY no lights at all in the dash. No codes.. i fixed that. I changed both batteries and abs rings. Now all is perfect
