New C300 owner. Basic function questions. Help is appreciated
Just got a 2008 C300 Luxury RWD as my new daily. Car is good shape for being 15 year old. And has only 65K miles on it. It obviously have some issues due its age but I am happy to have it.
I started with an oil change, air filter change, headlamp bulb replacement and aligment, new tires and a deep clean. Car came with new brakes
However I found some things that I need to work on.
1. Horn is not working. Fuse diagrams show the fuse number and relay to check, and they seem to be ok. However there are two 31A and31B slots, and the fuse is a 2 prone fuse. Have any of you guys work on this before? Does it need a three prone fuse? I will check the horn connections, but wanted to ask you guys first
2. The interior lights on the glove box and passenger footwell were not working, I replace the bulbs with some LED that I had from a previous car. However, the light in the foot well is always on while the vehicle is running. IS this a normal behavior? Is there any way to turn that off once we start driving it?
3. Have you guys used LED on the instead of the head lamp mini bulbs?
4. I have notice the temperature reading is always under 80 on the cluster, is this the normal temperature expected?
5. Have any of you use the pre assemble quick struts systems that are sold online? or go for the OEM type. While trying to save some money, I have considered the other option.
Next fixes / updates are the serpentine belt, new sparkplugs and will need urgently some front struts.
Thank you guys!
Cheers!
2. Get rid of the LED lights and install what is specified in the operator's manual (or elsewhere).
3. See #2. These cars are very sensitive to electronics.
4. Temp should run right around 200°F or right around 93°C. (Get a scanner)
5. Stay with OE, OEM, or genuine parts. FCP Euro, Pelican Parts, AutohausAZ, ECS Tuning, and RockAuto are good sources for parts.
Get yourself a Mercedes-specific scanner!!! My personal preference is LAUNCH Creader Elite BENZ, but iCarsoft MB V3.0 and Foxwell NT510 Elite are also good. Check Amazon.
I only install the bulbs that are specified.
The Mercedes thermostat is rated for 100 degrees C/ 212 degrees F. Its even stamped 100 C right on it. You should see the temp get up to 100 C then stay there or go a little lower when the thermostat opens. If its stuck open it may not get up to temp. If you happen to need a new one the Mercedes thermostat is actually Wahler.
For replacement parts I would only install Mercedes or OEM parts. Mercedes front struts I believe are Sachs. I would not use no name brands. Ill look around and see if I can find some deals for your struts.
For serpentine belt the length should be in your operators manual in the back. Should list it in mm. I like to buy parts at eEuroparts or FCP.
Was able to check fuse and relay and they do work, So, now need to check the horns.
What type of coolant you guys recommend?
https://operatingfluids.mercedes-benz.com/
Did you get a Mercedes-specific scanner or are you using a generic OBDII scanner? If you are using a generic scanner, save it for your Honda. I can give misleading results. You NEED a specific scanner for Mercedes, like I listed above in my first response. They are all well under $200 and will save you money on your first trip to the dealer when the generic scanner can't read the correct module.
I use the Zerex G48 50/50 Blue coolant. It is 325.0 Mercedes approved right on the label. I find it on sale alot at Napa autoparts. I think the 50/50 is just easier to use, no mixing needed.
Do you plan on replacing the thermostat? Its very easy to do. I recently replaced a leaking oil filter housing gasket and removing the thermostat was part of it. I did not bother draining the coolant from the radiator, i just removed the thermostat and let it drain out there. It saves a step.
When I did that work I ended up buying 2 jugs of the coolant and had a little left over. Def needed more than 1.
The drive belt and idler pulley has to be removed to get at the thermostat so it may be a good time to replace the belt. I also replaced the pulley since mine sounded like a skateboard wheel. Make sure to torque all the bolts to spec when done. I have those specs if needed. Mark the direction the old belt goes, I keep the old one in my trunk if I ever need it again.
I think the 35nm number below is if it were a new water pump and the bolt hole is not pre-threaded?. I followed the "follow-up operations" number of 25nm.
Thermostat is in, and working perfect.
Put new serpentine belt, air filters, air filter rubber seal, battery and spark plugs (the one in the vehicle had a gap twice the size), new sway bar links and a new horn. I did put a Liqui Moly injector cleaner on a fuel tank. Vehicle runs really nice now.... while it was not bad, you can tell a difference between nice and day.
Still need a work in progress but is nicer ride now...
Definitely want a pre-purchase inspection from a qualified Mercedes mechanic who knows the model and year. Someone or a service like this: https://lemonsquad.com/
Are you buying from a MErcedes Dealer or a used car dealer? Nothing on cARFAX or something similar?
I will try to give you some scenario, and my thoughts when buying my C300.
I needed a daily, I did not wanted to break the bank nor get a car credit
was not looking for a C300, I stumbled on it. I live in the rust belt, and this car is from the south, Arizona, So it was rust free and was clean on the interior, trunk engine compartment, and underbody. So this was a really big plus.
Now, I knew I was buying a 15 yr old car, and that things needed to be fixed, things will get broken. I did not know that you need an special scanner for example.
From the drive, we realize needed new tires a some new suspesion parts.
The only major repair, was to fix the manifold flaps, but I was able to do it, ran some issues with some parts that I ordered online, but was the shipper fault rather than other thing. I have changed the control arm, but that was more expensive than complicated.
I enjoy driving it a lot, the V6 has its beans, and it moves with ease. Crisp response from the steering wheel, and pretty good sound isolation even with 15 yrs old. Brakes pretty nice, and even with 45 profile tires is comfortable.
Radio sound pretty good, but you will probably missed some new tech, the bluetoot while works fine, only is for phone calls, not music.
While I am not a pro mechanic, I can hold my own So all repairs exept for the tire mounting has been done by me. I had to buy new tools, torx and inverted torx sockets and a Mercedes Scanner (this is your best friend). Since I lost all my previous tools, I also bought car jack, jack stands, pliers etc.....
There are other repairs done in the past few months, but still is less than a montly payment, or than a newer (cheaper) car like a Golf (nothing against a VW golf, but the quality of the drive and looks are not comparable)
So, as cons.
You have to use premium fuel or E85 which I have been using all sumer with no issues (My car is a flex fuel, but not all of them from what I understand)
Spare parts can be expensive.
Fuel economy is not the best one, around 24 MPG local roads, with no heavy foot.
Being old car, you will have to fix and repair things. If you are not going to do them and take it toe the mechanic the bill will get higher.
Pro
Car look and drives really nice
is easy to work, this is usually an common argument, but general repairs have been easy, took time but I am not a fast mechanic.
There are TONS of resorces of information to fix, upgrade, and troubleshoot the vehicle. Like this forum, or Youtube.
There are many sites to get parts from, and being and old model, partss are available at clereance sometimes
My car had 65K when I got it, is different than 156K so pretty sure the fix list might be higher... As recommended by JettaRed find a good mechanic to inspect it, ideally with a Mercedes Scanner.
And keep reading this Forum or others, I am pretty sure there are higher mileage issues that I have not encounter. But you can also see that a lot of people still drives these cars after 200 K miles....
Around 180k miles, there are moving things that start to wear out. They will have to be addressed to keep the car. No way around that.
The good part is that the W204 was the most popular Mercedes in the U.S., ever. They sold about 2 million of them. AND it shares the drive train, electronics, head unit, and many interior parts with the X204 GLK350. Parts are easy to get, often inexpensive, and salvage components are readily available.
I really like the looks and the fact that it's 6 speed is great BUT the Carfax and other reports say the car wasn't serviced since 2014!? MB in Oakland quoted a prepurchase inspection is $570; I'm not totally in love with the car so I'll skip the PPI.. This is over priced for the year and mileage if I can get it for <$6K it'll leave room for future repairs. I'll test drive it and see if I can work a better deal and let you know.
Thanks Again
I'm seeing a trend of outrageous labor rates AND quotes for a fixed labor amount without a breakdown of major steps that will be taken.
