Driver side seat cover - Choices
Old Feb 25, 2024 | 10:18 AM
meazz1's Avatar
C250 2013
I realize I need to address this situation sooner rather than later. Currently, I've a solution using sticky seat repair tape, but I'm considering whether purchasing a seat cover from eBay or Amazon. Removing the seat cover appears relatively straightforward, requiring just the removal of two torx screws. This means that if the aftermarket seat cover and reverting to the original cover or trying another inexpensive option shouldn't be of much difficulty.
However, the original cover repair by an upholstery shop right now because the sticky tape I've used could complicate matters. Do you have any suggestions on how best to proceed?
Here's the one I'm thinking of
Left Seat Cover Compatible with 2010-2014 Mercedes Benz C250 C300 C350 Left Seat Cover Compatible with 2010-2014 Mercedes Benz C250 C300 C350
Old Feb 26, 2024 | 08:20 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Just get the whole seat bottom from eBay. Take note of the exact interior code. Passenger seat will fit into driver if you remove the occupancy sensor bracket (not the sensor itself), and driver seat will not work for the passenger side because of the absence of said sensor.
This is the route I took, and bought a passenger seat for the driver since they're in better shape. And if that's mbtex, a bar of magic eraser will get that looking like new.
Old Mar 9, 2024 | 12:27 PM
meazz1's Avatar
C250 2013
Here's an update.
I bought the driver side seat cover from an upholstery place in Texas. It's made out of leather.
I wish it could be a little snug but overall very satisfied with the product.
Old Mar 12, 2024 | 12:53 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
If it is real leather you need to heat it up. Use a steamer to shrink the leather.
Old Mar 18, 2024 | 08:46 AM
meazz1's Avatar
C250 2013
So, to make the new seat bottom cover fit sung, I added an 1" foam cushion and the seat is more comfy and hopping it contours and breaks in slowly to right shape.
Old Mar 18, 2024 | 10:18 AM
TimC300's Avatar
Great idea with the extra foam. Looks like it fits much better.
Old Mar 29, 2024 | 07:06 AM
meazz1's Avatar
C250 2013
I had to remove the seat bottom again and improvise.
The snap in plastic did not stay secured with the metal track in the seat.
So, bought some clips, that helped but decided to drill holes and use hog rings to hold them.
