2014 C300
Well I just wanted to share my 2014 C300 with 67K on it. just thought you guy's would like to see it.
Also in my area at least, you don't see them like this anymore.
I love using the Turtle Wax Ceramic wet wax whenever I wash the car. Just spray it on after rinsing the car then towel dry the car. Works best if the pain is cleaned, I use a clay towel once in awhile to remove anything imbedded in the paint.
- Rear springs were rusted so replaced both. Again found a used set with 40,000 miles.
- Rear shocks were rusted but seemed fine, again I found a used set great condition with 40,000 miles so replaced them and I def see a difference.
- Rear dust shields were rusted through and the emergency brake springs wouldnt hold, popped out while driving.
- Oil filter housing and oil cooler gaskets were leaking so replaced them. I replaced the coolant at the same time which the manual says it was time anyways.
- Drive belt tensioner was bouncing so replaced it, drive belt and one of the idler pullers. Im about to replace the other idler pulley since i think its making a noise.
- Flushed brake fluid, which should be done every 2yrs anyways.
- Replaced front and rear differential fluid. Its not listed anywhere in the manual so I did it anyways.
- Replaced passenger side oil separator cover and oil drip pan.
- Replaced fasteners in the trunk trim due to water leaking into truck.
- Replaced broken exhaust clamps.
- Replaced dead battery.
- Replaced brake pads and rotors all around.
- Replaced front sway bar links.
- Replaced TPMS sensors all around.
- The transmission pan is severely rusted so I have everything to replace that and do trans fluid/filter change.
Heres my thread on the suspension work I did. Its long since i added other stuff: https://mbworld.org/forums/c-class-w...uspension.html
Heres the water in trunk thread: https://mbworld.org/forums/c-class-w...ar-window.html
This thread is long, has the oil separator cover, oil filer housing gaskets, other useless stuff: https://mbworld.org/forums/c-class-w...ks-yes-no.html
My trunk was leaking pretty bad, water in the spare tire well, spare towels stored in the trunk getting soaked. The replacement fasteners are part# 0009915940
The rear shocks took some effort to compress by hand and pull out quickly. To install the new shocks i compressed them and tied them down with string/zip ties. Made it so simple to install. Put the bottom bolt in, align the top mount with the holes then cut the string.
Dust shields were actually easy. Manual says to remove the hubs, the shield does not physically fit over it, which I wasn't about to do. I just cut the new dust shields in half with a hack saw evenly so theres 2 bolts holding each side. Just have to remove all the emergency brake parts, unbolt the old dust shield and snip it off with metal snips. Slide the new dust shield in place and bolt it on.
I got the car Nov 2019, I try to write everything I did down. I forgot to write down a few things. I started writing threads to remind myself.
What is your car sitting at height wise? Mines the 4matic Sport and I measured from the ground to the fenders. 17" stock rims.
Front is around 24-5/8".
Rear is around 25".
